When you have dropped your roof manually ie using rope and removing motors is there a sequence to putting it back up?
George
Roof Problems
georgeil773480
Veg_Ian
Re: Roof Problems
Not sure what you mean George. Bringing the roof down as a manual procedure usually means a problem and you've had to disconnect the motors to do this. You would then replace/reconnect the motors and fix the electrical fault and then off you go (after disconnecting the rope of course!)
