Rear Light Cluster Replacement
Croz
Post by Croz » Mon May 18, 2009 5:07 pm
Bashed the drivers side rear cluster on the way back from the Scottish Bongo Bash :oops:
Have down loaded the Fact Sheet for bulb replacement but would like some tips to access and change out the whole cluster if someone has done this before. I imagine I'll have to remove the inside panel - is the first job to remove the rear seat belt bolts and then do I just lever the panel off? I couldn't see poppers like those on the rear door..........
All guidance much appreciated.
Re: Rear Light Cluster Replacement
Post by Doone » Mon May 18, 2009 5:12 pm
Ouch. I 'searched' and found Kirsty had written up THIS advice on replacing the rear light cluster.
Croz
Post by Croz » Mon May 18, 2009 5:18 pm
#-o Ok so I've found the two scewsrefered to on the factsheet - Opened the rear door and there they are!! So it should be more straight forward than I thought.
Off to see the bodyshop man tomorrow to talk sctrach/dent repairs.........
Croz
Post by Croz » Mon May 18, 2009 5:24 pm
Thanks Doone, That was quick - your message must have crossed with my last one. I did a search before posting and didn't pick up on MissFixit's but that confirms what I found.
mister munkey
Post by mister munkey » Tue May 19, 2009 1:00 am
A tiny word of advice.
The last two times I've had to change mine, I've "thumped them out" a little too firmly & snapped a lug holding the unit in.
Gently gently is the way.
[-o<
jaylee
Post by jaylee » Tue May 19, 2009 1:07 am
mister munkey wrote:A tiny word of advice.
[-o<
I find, slowly slowly catch a monkey... :D
Croz
Post by Croz » Tue May 19, 2009 1:15 am
Thanks MM - wish me luck.
Post by haydn callow » Tue May 19, 2009 2:03 pm
secret is to push the light cluster outwards to remove.....if you just bash it backwards it will bust the lugs... As in the link to Kirstys post above>
Croz
Post by Croz » Tue May 19, 2009 5:04 pm
Haydn,
Thanks for chiming in - I have Kirsty's advice in mind and am just awaiting the new cluster to arrive before I dig out the screw driver.
Cheers.
