I have tried increasing the idle speed slightly (I guess its now around 800 rpm in neutral) which has helped matters a bit.
Could changing the cambelt (and the subsequent alignment of the new belt) lead to such vibration ?
It's a 1995 diesel Bongo with 97Km on the clock. The car starts fine and there is no apparent vibration problem when moving. Since the cambelt change, I believe the engine noise to be higher .. but it's hard to compare !
Need to compare vibrations with someone else
