flashgordon69 wrote:Where can i buy a new rear heater matrix from?
Mine is leaking
Bell Hill Motors (advertise on here) break Bongos. Bongobits too I think. Also check ebay.
People (converters especially) often take the rear heater out and make do with the front. I would imagine you could just take yours out of circuit by connecting across the hoses while you sort out a replacement at your leisure (essential to make sure you know proper bleed procedure after you've done the job, although they say that without the rear heater, bleeding a Bongo is a lot less tricky). I wonder if it would matter if it was a Bongo one just as long as it fitted (you'd think there might be other generic ones out there you could get as new replacements, with a bit of research).
But I'm not a great 'techie' so maybe someone better will offer a view shortly.
Good luck - keep us posted
Mike
