Cruise control info required
srs41
Planning on fitting an Audiovox cruise control , any one know the pulses per mile of the Bongo speed sensor .
Re: Cruise control info required
No idea for miles but if this helps.
Quoted from the Waeco MS-50 manual.
So I would guess it must be about 12,800.If the Cruise Control takes over at a speed of less than 40kph but no longer functions at speeds over 80-120kph and the LED flashes more than once per second, the black wire loop on the electronic module will have to be cut. This will change the impulse count from 1,250 per km to 8,000 per km
srs41
Thanks for that , I worked it out by trial & error , there are 4 settings to choose from tried them all & everything seems ok at 8000 PPM ,
