First off A big hello to you all, i've been relatively BONGO trouble free, so ain't been around that much .
Tho i've had the odd look now and again
I thought i had a small coolant leak in the small hose on the left as you look from the front, at the conection at the bottom of the radiator. Looked like the pipe or possibbly the radiator connection.
so i thought all i had to do was pull off the pipe and cut it back. Just assumed coolant would come out .
No its tranny or gear oil, cut it back and replaced hose.
IT was def leaking coolant so i assume its the radiator.
I take it this is just some sort of gear oil cooler. Or is it the engine oil cooler?
I assume i can just take the radiator out and have it repaired.
I'D appreciate any imput on this cause, im happy to follow in the footsteps of those who know as opposed to leading blindly from the front.
NOW FOR MY NIPPLE PROBLEM.
While I was doing this I took off the air ducting above the radiator , TO SEE COOLANT LEAKING FROM THIS NIPPLE ON THE RADIATOR CAP HOUSING.
There was no hose attatched and it is not blanked off.
Question is should this be blanked off (i'm thinking this could be a radiator off a ranger? so slightly different).
Or should there be a hose attatched and where is it?
Worst thing is it's Saturday and if you can still afford to put diesel in the bongo you'll all be out.
