leisure battery?
Bongoing Mad
leisure battery?
Post by Bongoing Mad » Sun Jul 12, 2009 10:53 pm
This probably is a dumb question but how do I tell if my 2nd battery is set up as a leisure battery? :?
Re: leisure battery?
Post by g8dhe » Sun Jul 12, 2009 11:11 pm
Do you have anything that would use a L/B ?
Disconnect the S/B and see if you can start the engine, if you can then you don't have a L/B !
Trace the wiring ?
stilldesperate
Post by stilldesperate » Mon Jul 13, 2009 12:08 am
Does the second battery positive run directly to the starter batt pos? (There might be an in-line fuse). If so, it's not a leisure batt.
If the wiring from it goes into a relay, or dissapears into the cab, then do what G8dhe suggests.
HTH
SD
"The older I get, the faster I was"
