COOLING FANS
oglivy0
COOLING FANS
Post by oglivy0 » Thu Jul 16, 2009 10:36 pm
Can anyone tell me where the senders are located for the scavenger fan and cooling fan.
Also,i`ve noticed that sometimes.after a run,if i switch off,wait a minute,then turn the ignition on,the scavenger fan cuts in.
I would have thought the fan would be better wired up with a direct live. :idea:
What do you think?.
daveblueozzie
Re: COOLING FANS
Post by daveblueozzie » Thu Jul 16, 2009 11:08 pm
The scavenger fan cuts in when the engine is hot, so after a run, when you stop no air is circulating around the engine so the scavenger fan comes on to cool the engine. don't send a direct feed to the fans because the sender unit may not work with a full 12volt feed,
Lost without my Bongo.
Re: COOLING FANS
Post by mikeonb4c » Fri Jul 17, 2009 12:05 am
I've had a direct (switch and fused) feed on mine for some time with no ill effects :D
brorabongo
Re: COOLING FANS
Post by brorabongo » Fri Jul 17, 2009 9:25 am
Radiator fan.....
The broken component (little bit of white wire sticking out) on the drivers side screwed to the head. In this case the rad fans would be constantly on as soon as the key was turned.
If you find this connection and disconnect it with ignition on (AFAIK) you will find that the rad fans will come on.
Disconnecting of the scavanger fan sensor (plug beside handbrake) whilst engine running /ignition on? will start the fans on a timed run.
ボンゴの激怒 pictures
