installing a 'real' temp guage?
Hi all, is there a compatible temp gauge you can fit instead of the "i'm going to stay at 11o'clock' one on the bongo's?
thx
thx
Re: installing a 'real' temp guage?
the neatest solution I found was the mason alarm, it both removes the "damping" of the original so it moves around and more accurately reflects what is going on, plus it has an audiable alarm. Easy to fit and discrete.
You can add a normal gauge, you'd need to wire it in, find somewhere to house it, and install a new sender unit.
Or maybe you could add an oil temp gauge ...
Lots of discussion on here about the options, but I, like others, went for the mason, it's easy to fit, well priced, and tried and tested.
Andy
Andy
Second what Apole said - http://www.townace.plus.com/ie/ietemga2.htm - dead easy to fit & you can set the alarm where you want
Got a Mason fitted meself...
A bit scary to start with the needle sits one'ish..
It also alerted me to stop when my top hose went back last year! (I would have never noticed the steam till it was way too late.)
One thing i would say is if you do decide to fit one, (or even change the dial completely.) let the garage know (if they are likely to undertake any work) of the mod & where the needle normally sits... It will save alot of head scratching on their part!!
The other option is of course the TM2 - http://www.coolantalarm.co.uk/index.php ... at&catId=5 - or just get a cheap digital temp display with a probe, I got one from fleabay for around a tenner I think, no alarm & no illuminated numbers, but it gives a running temp readout.
That will also show you what a chocolate fireguard the standard alarm is - watch the numbers change and watch the standard gauge do eff all.missfixit70 wrote:The other option is of course the TM2 - http://www.coolantalarm.co.uk/index.php ... at&catId=5 - or just get a cheap digital temp display with a probe, I got one from fleabay for around a tenner I think, no alarm & no illuminated numbers, but it gives a running temp readout.
I had the TM2 alarm & fitted (by Haydn) at the Stourport Bash--i was a bit paranoid about overheating issues
Regards Ray & Christine
thanks all - bought the mason alarm - will attempt to fit it at the weekend
- looks fairly straight forward..
The only dilemma you might have, is where to put the alarm box...
Gis a shout!
Gis a shout!
Fitted mine in the fuse box with the adjustable screw bit by the hole in the cover.
damn!dobby wrote:Fitted mine in the fuse box with the adjustable screw bit by the hole in the cover.
I put mine here...
I kind of like the old Marshall amp look about it!
I did drill a hole in the back to help with the alarm acoustics...
I got one last week too - bit I can't fit it since I haven't go the Bongo to go with it yet!bought the mason alarm - will attempt to fit it at the weekend
Still, doesn't hurt to be prepared!
I'm surprised you haven't added extra numbers to take it up to 11 Jamiejaylee wrote:damn!dobby wrote:Fitted mine in the fuse box with the adjustable screw bit by the hole in the cover.![]()
That never occurred to me..
I put mine here...
Good reminder about drilling out the back to increase the alarm volume, did mine too. Mines stuck out of sight behind the dash.
Dave Mason
That's interesting. I've often wondered if the Mason alarm would pick up a burst hose. Some people say that the de-pressurisation will cause the temperature to drop rather than rise or that the lack of coolant around the sensor will render it useless. No-one of course wants to experiment. So your misfortune has provided some useful information. Thanks.jaylee wrote:Got a Mason fitted meself... alerted me to stop when my top hose went back last year! (I would have never noticed the steam till it was way too late.)
By the way, with new head, rad and hoses I've reset Mr M's alarm to 4. What's everyone else using?
