Bingo ! Found where my ongoing oil leak was coming from.
Had a new rocker cover gasket fitted as it was a bit leaky,cured it
a bit but had a little drip-drip still.
Today i found out it's the sump gasket leaking.
Anyone had similar probs ?
Any advice ?
Diy home job or best left to a pro ?
Thanks in advance.
Mike.
Sump gasket.......
Gert The Green
Re: Sump gasket.......
On the V6 petrol there is no sump gasket, just a sealant that is used, allowed to start setting before reassembly.
On lushprojects for the diesel it looks the same.
I had mine done by discount trucks as it was in for other work anyway at the time, can't recall what sealant they used, if you DIY shop around and find a good flexible, oil and heat resistant sealant.
Hope this helps.
Andy
Hope this helps.
Andy
Gert The Green
Cheers Andy,
Aye,a mate just told me the same advice,just surprised a bit of mastic
sealant is all it takes
When the rain stops i may attempt it
Mike.
Mike.
