Wheel Arches Rusting
serge
Post by serge » Sun Aug 09, 2009 11:55 am
Hi all
The rear wheel arches on my Bongo have started to blister, I had a cheap job done last year and they are bubbling again, my fault, you get what you pay for. I have decided to get the job done properly and to get the sills done at the same time.
Any suggestions on the best course, ie do I get the rusting parts cut out and replaced or simply rubbed down properly and repainted, and is there such a thing as a replacement arch available, whether rubber or metal. I am based in Northants, so if anyone can recommend anywhere to do this, your help will be greatly appreciated
Serge
westonwarrior
Re: Wheel Arches Rusting
Post by westonwarrior » Sun Aug 09, 2009 12:32 pm
http://www.igmaynard.co.uk/bongo/forum/ ... 35&t=31898
In the link is a post about Ian sourcing new replacement wheel arches
Not sure how far down the line this is but may be worth e-mailing Ian and finding out and waiting a bit to get the new ones
Aunt Trumpet
Post by Aunt Trumpet » Mon Aug 10, 2009 5:54 pm
Mine are doing the same unfortunately.. :( I think its pretty common on the northern Bongo. I'm going to have a go on mine next spring when I have a bit more time and to be honest it'll probably come back but I won't have to spend hundreds doing it. The only proper way of doing it will be to cut all the rust out and re-weld new in. You pay your money and take your choice. :?
Post by bigdaddycain » Mon Aug 10, 2009 8:07 pm
Some have cut out the offending rusty arches, and replaced with sound S/H arches from a breaker bongo... Maybe Haydn will post up his pics of his arch job? Very comprehensive pics on how to from him... :wink:
Post by missfixit70 » Mon Aug 10, 2009 8:45 pm
Scoobie
Post by Scoobie » Mon Aug 10, 2009 11:45 pm
I've got the same problem with Scoobie. It's been suggested that I contact Ian - i'm probably being a bit slow :? but I can't work out how to do that??
I'm really scared of getting stung on this financially - I feel my complete lack of knowledge will put me at a disadvantage.
Anyone know of a trustworthy body shop that might take on such a task - in South wales
Cheers :P
Post by Ian » Tue Aug 11, 2009 10:11 am
Rear wheel arches are on the way (from Malaysia) and we will publish details on main website, together with list of body shops who can undertake the work, when they arrive.
Lewy
Post by Lewy » Tue Aug 11, 2009 11:52 am
I've just patched up mine by sanding back to the metal, primed using some hammerite antirust primer, sanded back again and filled the any fine holes with Spat O Rapid, sanded off, re-primed with spray, then dusted with top coat and then clear laquer. Very pleased with the job really and the colour match - the key seems to be doing a bit of overpsraying then cutting back with polishing compound to get a nice blended match. I imagine that I'll be lucky to get another year out of them before they need replacing or re-doing, but didn't cost me anything as I had all the paint etc in. I do need to do a couple of points on the bottom colour skirt - that I didn't have, so will finish that when the paint arrives.
I cleaned off the inside of the arches too and primed and resealed with waxoil underseal.
Post by mikeonb4c » Tue Aug 11, 2009 1:06 pm
Lewy wrote:I've just patched up mine by sanding back to the metal, primed using some hammerite antirust primer, sanded back again and filled the any fine holes with Spat O Rapid, sanded off, re-primed with spray, then dusted with top coat and then clear laquer. Very pleased with the job really and the colour match - the key seems to be doing a bit of overpsraying then cutting back with polishing compound to get a nice blended match. I imagine that I'll be lucky to get another year out of them before they need replacing or re-doing, but didn't cost me anything as I had all the paint etc in. I do need to do a couple of points on the bottom colour skirt - that I didn't have, so will finish that when the paint arrives.
Sounds a good job. I'll be v. interested to hear how long it lasts as I still can't believe that a well prepped job can't go for quite some time. Fingers crossed for you [-o<
neil/di
Post by neil/di » Wed Aug 12, 2009 9:40 am
Hi Ian,
Any more news or info on the wheel arches, as I am looking to get mine done shortly
Neil
A Bongos is not just for christmas
Post by Ian » Wed Aug 12, 2009 9:52 am
They are on the way. Keep an eye on main website for latest news.
neil/di
Post by neil/di » Wed Aug 12, 2009 4:14 pm
Thanks Ian,
I am on hols next 2weeks, and dont want to miss out
Neil
corrour
Post by corrour » Fri Aug 14, 2009 8:44 pm
Hav a look at thease.
Some More Pics http://picbite.com/gallery/43035fmcjk/
Its in paint at the moment so more pics soon.
Had the arches made by a local metelwork company after giving them a template and profile of sills
if its all a sucsess they may produce sills in 1metre lengths
The made em of 1mm steel so should last.
john :shock: :shock:
I would walk 500 miles.
99 Tinted tintop
Supplied and looked after by Bongospares
Post by missfixit70 » Fri Aug 14, 2009 8:57 pm
With so many people needing rusty wheelarches replaced & people wanting the wheel arch spats/trims or whatever you want to call them, is someone not going to bit the bullet & get some wheelarches sorted that have a bigger flare on them? Kill two birds with one stone? 8) making sure they don't foul on the sliding door of course :wink:
Post by francophile1947 » Fri Aug 14, 2009 9:24 pm
missfixit70 wrote:With so many people needing rusty wheelarches replaced & people wanting the wheel arch spats/trims or whatever you want to call them, is someone not going to bit the bullet & get some wheelarches sorted that have a bigger flare on them? Kill two birds with one stone? 8) making sure they don't foul on the sliding door of course :wink:
--and made of fibreglass, so they can't rust again :lol:
