Snakes.
tachometer
tachometer
Snakes.
Re: tachometer
Has it been chipped to read MPH? that often causes problems.
aitch
- Location: in a place far, far away, well Somerset for now!!!
Re: tachometer
are you talking rpm (tacho)The tacho
or mph (speedo)??
Re: tachometer
Tacho is a speedo Aitch, at least it is to my understanding
Re: tachometer
Every blue moon my speedo flutters, flies to the top of the gauge, drops back to zero, then resumes at the correct speed.. This all takes place in a matter of a second. I suspect my speedo chip, but the problem is too intermittent to bother replacing it.
- dandywarhol
Re: tachometer
Tachometer is the correct name for a rev counter. A proper rev counter counts revs, a tachometer reads them out in revs/min.missfixit70 wrote:Tacho is a speedo Aitch, at least it is to my understanding
Re: tachometer
In that case I stand corrected, I've always taken it that a tacho, as in a tachograph as well, reads/records speed.
Re: tachometer
It depends who you're talking with - anybody who drives a vehicle with a "Spy in the cab" will use "Tacho" for Tachograph.missfixit70 wrote:In that case I stand corrected, I've always taken it that a tacho, as in a tachograph as well, reads/records speed.
Talk with anybody in motorsport circles and "Tacho" will be taken to mean Tachometer.
As for the truckies who drive the trucks that carry the racing cars - they must just get very confused.
aitch
Re: tachometer
I have always read tachometer as the correct name for a rev counter.
but understand the confusion with tachograph
sorry to have muddied the waters Kirsty.
Re: tachometer
If it is the rev counter that's causing the problem - this may help - http://www.igmaynard.co.uk/bongo/forum/ ... er#p220524
- dandywarhol
Re: tachometer
I think Mexicans also use it in their weightwatchers programme as a food consumption diagramaitch wrote:I have always read tachometer as the correct name for a rev counter.
but understand the confusion with tachograph![]()
