Thanks to all who responded to the previous thread. Our Bongo has been in the garage for some weeks now, but still will not run properly. It still gets hot, starts to bubble and ejects coolant. Here is what happened.missfixit70 wrote:Continued from this thread - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=33562
Since our last post, our local garage has removed and flow tested the radiator. No problems there. Having already replaced a leaky water pump, and replaced the stat and gasket as a precaution, we were left with the conclusion it must be a problem with the head / head gasket. Off came the head and away it went to be pressure tested for cracks and to be skimmed. Great news! Nothing wrong with the head. Trouble was, the old head gasket did not look that bad. Hard to see any evidence of where it might have failed. Anyway, the garage fitted it all back up and carefully bled the system, a job they are getting quite expert at!
Same old bubbling and steaming. They took out the stat. No improvement. The top hose gets warm, but the lower hose refuses to. They persevered with trying to bleed the system and were rewarded with a lower hose being blown off!
All this pressure must be coming from somewhere. The Garage feels there must be a crack in the block. Ouch! and Double OUCH!
Can anyone help with anything obvious we are missing?
Thanks in advance
Al
