Bongo stalling
Grim up North
Bongo stalling
In the last week my Bongo has stalled a few times while at junctions etc,always first thing on a morning when its 'cold' also takes a bit of starting,had no problems until recently and once it has run for 15-20 mins its fine,could it be in need of a fuel filter change or heater plugs or could it be injectors which i have been told could be expensive.
Re: Bongo stalling
Glow plugs are favourite, although I would expect it to run fine in less than 15 minutes
Re: Bongo stalling
Go for the easy things first, change the fuel filter (fill the new one with injector cleaner) & check the banjo filter/strainer, check the glow plug relay is doing it's job & the glow plug rail is getting it's voltage when it should.
Grim up North
Re: Bongo stalling
Thanks,i have since posting, booked it in for a service so i will mention these things i have done 1500 miles since the Tan Hill meet with no troubles,i am sure it will be something simple
