coolant levels....cloudy header tank
Pablobongo
Post by Pablobongo » Tue Sep 15, 2009 7:13 pm
Hello all......trying to find the thread for checking my header tank level with a lolly stick!.....i have a low coolant alarm, so know its not that low, but i remember reading on here that you can dip a lolly stick into the header and visually check the level that way......but how far up the stick should it read in cms?.....
Paul 2002 V6Image
Re: coolant levels....cloudy header tank
Post by haydn callow » Tue Sep 15, 2009 7:33 pm
2 cms
Post by Doone » Wed Sep 16, 2009 10:54 am
The coolant dipstick info: LOLLY DIPSTICK HERE and PENCIL/LOLLY DIPSTICK HERE
lev8
Post by lev8 » Wed Sep 16, 2009 1:12 pm
Why not give the tank a good clean and you will be able to see the level.
this is how I did mine
Leave the pressure cap on header tank, remove one hose at a time and plug it and the tank outlet, a rubber glove finger and rubber band for instance
get a suitable container and drain the tank, by removing the cap.
remove tank from vehicle
I found phosphoric acid to be most effective, also Calcium, Lime, Rust (sulfamic acid) was good too.
It takes a while, hours... agitation helps. let it soak a while, shake it and so on
After the tank was clean, I thought it might have been quicker with a bit of abrasion, but you can't get in there with a bottle brush etc. Whatever you use, must be completely removed. One thought is a number of small ball bearings, count them in and count them out. Shaking with an abrasive will be much more effective.
When clean connect hoses first and then top up with reserved fluid.
good luck
Pablobongo
Post by Pablobongo » Wed Sep 16, 2009 7:15 pm
Thanks for the replies all......did the dipstick test and she was spot-on!.....lots of lovely coolant,exactly where it should be!!
Paul 2002 V6Image
