Hi everyone, I would like to get the front foglights working as they dont at the moment. There is an OEM switch which seems to work according to my multimeter (though it doesnt light up when depressed?), all the fuses seem ok, there is power to the switch so where do I look next? The bulbs are ok, just thinking if there is a standard place for a relay for me to check?
Hope you can help, many thanks, Patrick
Front fog lights
ptatham
Re: Front fog lights
Try inside the passenger side wing under the bonnet? I know this has come up before, have a hunt around using the search function.
They don't.. They just illuminate with the dash...ptatham wrote:Hi everyone, I would like to get the front foglights working as they dont at the moment. There is an OEM switch which seems to work according to my multimeter (though it doesnt light up when depressed?), all the fuses seem ok, there is power to the switch so where do I look next? The bulbs are ok, just thinking if there is a standard place for a relay for me to check?
Also, try fuse 10 (15A) under the bonnet?
gbrockley
Hi, I had exactly the same problem as you describe with the front foglights. After much fault searchingptatham wrote:Hi everyone, I would like to get the front foglights working as they dont at the moment. There is an OEM switch which seems to work according to my multimeter (though it doesnt light up when depressed?), all the fuses seem ok, there is power to the switch so where do I look next? The bulbs are ok, just thinking if there is a standard place for a relay for me to check?
