sliding door window come adrift - help?
saracen
Post by saracen » Tue Dec 08, 2009 12:58 am
The fastener on the sliding door window has broken, so that the glass is basically flapping about.
Ahy ideas? Do we need a new window or can it be fixed somehow? Can anyone help? Thanks!
Re: sliding door window come adrift - help?
Post by missfixit70 » Tue Dec 08, 2009 2:44 am
Get a new fastener from a breaker's? Has it just come unbolted or is it actually broken?
This may be of some help - http://www.igmaynard.co.uk/bongo/forum/ ... =5&t=36366
scanner
Post by scanner » Tue Dec 08, 2009 9:43 am
The bottom front fastener came out on mine, all you need to do is get a new one and fit it.
jaylee
Post by jaylee » Tue Dec 08, 2009 10:11 am
This may help you... http://www.lushprojects.com/bongopartsm ... 1of02.html sounds like part 99832-0410 may have unscrewed from 70-361A..?
Is 70-361A part still in the glass? there's a possibility the screw part could still be caught in the hinge clasp mechanism 72-310Y? (If yer lucky!?)
I would check the rest are not loose too! :wink:
maxheadroom
Post by maxheadroom » Tue Dec 08, 2009 7:21 pm
aren't they the same as mid 90's Mazda 121 :?:
Keep the Faith
scanner
Post by scanner » Tue Dec 08, 2009 7:57 pm
maxheadroom wrote:aren't they the same as mid 90's Mazda 121 :?:
If they are, then they are the same as the identical Ford Fiesta.
and possibly cheaper at a Ford dealer.
saracen
Post by saracen » Wed Dec 09, 2009 8:09 pm
Thanks for all the help - will check out links when home again. It is totally broken I think - we ar left with a hole in the glass and a screw projecting from the black 'latch'.
scanner
Post by scanner » Wed Dec 09, 2009 8:13 pm
saracen wrote:Thanks for all the help - will check out links when home again. It is totally broken I think - we ar left with a hole in the glass and a screw projecting from the black 'latch'.
The hole in the glass is where the "mushroom" headed bolt thing does through and the screw fits into that.
saracen
Post by saracen » Wed Dec 09, 2009 10:29 pm
Jaylee - thanks so much for this link which I've been able to take a look at now I'm back home; we now know how the thing fits together! Will take a look tomorrow when we have daylight to work by and see exactly what's broken/missing. Thanks again.
Gill
jaylee wrote:This may help you... http://www.lushprojects.com/bongopartsm ... 1of02.html sounds like part 99832-0410 may have unscrewed from 70-361A..?
Post by Bob » Wed Dec 09, 2009 11:26 pm
This is a small enough part for one of the breakers to post it to you very quuickly, and should be simple to fit.
Good luck. :)
jaylee
Post by jaylee » Thu Dec 10, 2009 10:11 am
Make sure you still have the rubber grommet too..? part number 70-525. (They normally stay stuck to the window hole.) There should be two of them either side of the window glass, otherwise no matter how hard you tighten up the bolt it will always appear loose!
... I think from memory, they only tighten up so far anyway to protect the glass..?! :wink:
I took all mine out & repainted em back in the spring along with the wiper arms, they were looking more than a little tired! :D
In fact i noticed the paint coming off the bolt heads & rust scoring down the windows on some of the newer Ford KA's.. The Bongo/Freda bolts are more like an alloy & don't seem to cause this problem with the rust..? So bearing in mind that the bolt is some sort of alloy, be careful on the tightening up!!?? #-o
saracen
Post by saracen » Thu Dec 10, 2009 1:41 pm
Thanks so much to everyone - we have at last been able to get a proper look at the problem, take the window apart and put it all back together, and all is well. We have the grommets safe and sound jaylee! It will be so nice to drive around without that ominous rattle and the ornamental gaffer tape decorations...
