Page 1 of 2
scavenger fan
Posted: Tue Feb 09, 2010 8:14 pm
by phatgit
not wanting to sound a numpty, but whats it for and whats it do? does it cut in automatically? and i assume its the one you see when the passenger seat is lifted
Re: scavenger fan
Posted: Tue Feb 09, 2010 8:37 pm
by francophile1947
Re: scavenger fan
Posted: Tue Jun 22, 2010 7:23 am
by Darkstar
not wanting to be a bigger numpty,
but where is it, i see the two fans behide the radiators, but i dont see any others?
Re: scavenger fan
Posted: Tue Jun 22, 2010 7:53 am
by daveblueozzie
The fans are at the bottom/underneath the engine, it cools the air around the hot engine when the vehicle isnt moving, like franco said, you may only hear it after a long run when you stop .
Re: scavenger fan
Posted: Tue Jun 22, 2010 8:07 am
by widdowson2008
To see it, you need to lift the engine cover and look toward the front of the engine, low down.
dbo beat me to it
Re: scavenger fan
Posted: Tue Jun 22, 2010 11:26 am
by Darkstar
Ok found it thanks, tested by shorting plug beside h/brake,as per other posts. lets hope sensor works.
Re: scavenger fan
Posted: Tue Jun 22, 2010 6:13 pm
by Tripewriter
I am not sure it is there to cool, I think it is there to prevent any build up of gasses whilst sitting in the Tokyo traffic. (I understand they have a lot of traffic).
Re: scavenger fan
Posted: Tue Jun 22, 2010 6:29 pm
by widdowson2008
Tripewriter wrote:I am not sure it is there to cool, I think it is there to prevent any build up of gasses whilst sitting in the Tokyo traffic. (I understand they have a lot of traffic).
Whilst the gas/fume removal is a valid point, I think you may find it is primarily for heat removal because the fan is triggered by the ECU receiving a signal from a sensor in the engine bay. This sensor is a temperature sensor, not a gas sensor. It is my belief that the fan is activated when the temperature in the engine bay reaches a level where it threatens the integrity of the electronics/wiring stuff in the bay.
Re: scavenger fan
Posted: Tue Jun 22, 2010 6:35 pm
by Tripewriter
Thats interesting where is the sensor that triggers it?
Re: scavenger fan
Posted: Tue Jun 22, 2010 7:49 pm
by jaylee
Tripewriter wrote:Thats interesting where is the sensor that triggers it?
By the handbrake i believe..
Re: scavenger fan
Posted: Tue Jun 22, 2010 7:51 pm
by jaylee
Darkstar wrote:Ok found it thanks, tested by shorting plug beside h/brake,as per other posts. lets hope sensor works.
I do declare it is!!
Re: scavenger fan
Posted: Tue Jun 22, 2010 7:54 pm
by Northern Bongolow
as jaylee says its the black plastic looking probe that is mounted behind the handbrake, facing down to the rocker cover.
Re: scavenger fan
Posted: Tue Jun 22, 2010 8:02 pm
by Doone
It cut in automatically when the cylinder head failed on ours a couple of years ago.
Re: scavenger fan
Posted: Thu Jul 01, 2010 2:28 pm
by fivepints
er, is this the big fan that cuts in with a tick - sounds like an intercooler fan? Mine comes on all the time! Is this bad??
Re: scavenger fan
Posted: Thu Jul 01, 2010 2:38 pm
by widdowson2008
fivepints wrote:er, is this the big fan that cuts in with a tick - sounds like an intercooler fan? Mine comes on all the time! Is this bad??
On mine (and I think others too) I get the front fans cutting in with a tick when the aircon is switched on. More noticeable when engine is running, aircon switched on, and vehicle not moving - fans switch on and off and on and off and......
I thought it was to compensate for a lack of air flow present when moving, to prevent any heat radiating from the main rad to the aircon rad (thingy)
