i bought some blanks, to blank the erg , now these are not quite the same shape as the place where they are going to fit,
theres a small bit of the blank which sticks out .
when i came to do the job, the existing seals ? have the same sticking out bit , so does this mean its already been blanked ??
or are the seals/plates what ever they are called , not blanks ,and the shape is normal .
or do i have to take it to bits to find out ???? nooooooooooooooooooooo, nooooooooooooooooooo.
is this egr valve already blanked ???
Re: is this erg valve already blanked ???
Is it gasket material sticking out or metal.
If metal then it's probably blanked?
Only one way to find out................
Does this help? http://www.lushprojects.com/bongopartsm ... mgno=.html There should be a gasket in the joint so it could be that you are seeing.
Blanks and real gaskets (with a hole in the middle) are the same overall shape. The sticky-out bits are so you can move them around when re-assembling to get the holes to line up for the bolts.
bobngo
they are made of steel, but there seems to be only one way to find out for sure *&$%^£"
Take the front one out - it's pretty easy. The one at the rear of the head is more fiddly.
Re: is this egr valve already blanked ???
When I blanked mine the existing gaskets were very thin stainless and sticking out as you describe. So , only one way to be sure, take a look at them.
