do the horns operate through a relay
bobngo
Post by bobngo » Fri Mar 05, 2010 2:54 pm
i have just purchased some nice duo tone air horns ,which need to be operated through a relay, are the existing horns running through a relay, in which case i need not fit the relay which came with the new horns.
Re: do the horns operate through a relay
Post by Simon Jones » Fri Mar 05, 2010 3:41 pm
Can't recall, but if you unplug the horn & something clicks when you press the button then you have got one. I just used the feed to the old horn to run a new relay on a seperate fused feed frome the main battery.
Post by Muzorewa » Fri Mar 05, 2010 3:44 pm
There is a group of relays behind the offside headlight, one of them is for the horn :wink:
Post by g8dhe » Fri Mar 05, 2010 4:53 pm
Yes, you don't say what type and it varies;
the circuit
and the location of the relay (note it shows two positions for F3-03 depending on type);
bobngo
Post by bobngo » Fri Mar 05, 2010 8:15 pm
so the horns are fed through a relay, then i can use that
thanks everyone
