fitting a new water pump and on the fact sheet its says
2. Climb underneath. (I removed the engine fan so I had somewhere to rest my
head!)
how to you remove the engine fan cant find a fact sheet on it
how do you remove the engine fan
stansyerman
Re: how do you remove the engine fan
I would think it is the scavenge fan that is being referred to, to give better access to the front of the engine - part no 15 035 on the diagram here. you can see the fixing points on the fan http://www.lushprojects.com/bongopartsm ... mgno=.html it should be reasonably self evident how to remove it when you're under there?
its the big electricfan as she says
removing it i found the hardest part of the job
as the jap who put it in
must have had hands a tenth the size of mine
Go to Halfords buy some ramps this will help no end i THINK i PAID £39-99missfixit70 wrote:I would think it is the scavenge fan that is being referred to, to give better access to the front of the engine - part no 15 035 on the diagram here. you can see the fixing points on the fan http://www.lushprojects.com/bongopartsm ... mgno=.html it should be reasonably self evident how to remove it when you're under there?
sPARKY
