Oil change and copper washer
Scott & Gillian
Post by Scott & Gillian » Sat Mar 27, 2010 8:27 pm
I'm going to change the oil and filter on the van shortly.
I've read that I should change the copper washer when I do it.
Anyone know what size washer I need before I take it all apart??
I'm a collector of random things. Anything. But not glitter, which is nasty.
www.random-things.co.uk
Re: Oil change and copper washer
Post by missfixit70 » Sat Mar 27, 2010 8:31 pm
Can't tell you the size, but you could just anneal the existing one - http://www.motorcycle.co.uk/Reference-m ... shers.aspx
steviebongo
Post by steviebongo » Sat Mar 27, 2010 8:33 pm
Depends where u get ure filter from if it's a local mazda dealer then the sump plug washer that they use will fit, I know cause i used one of these yesterday on a bongo diesel.Best of luck.
cheers stevie
Post by mikeonb4c » Sat Mar 27, 2010 9:01 pm
Golly. I bought one when I did my 1st oil change. Can't remember very well but I think it was a 19mm one, sold in Halfords as suitable for a Vauxhall something or other. But then I got a Pela pump and all my oil changes since have been done by sucking old oil out the dipstick hole. Makes the job an absolute breeze and no need to remove the sump plug. Highly recommended if you've got about £30 to spare and fancy treating yourself. 8)
bobngo
Post by bobngo » Sat Mar 27, 2010 9:09 pm
just measured a spare i have here its :-
material copper
inside diametre 14.5 mm
outside diametre 20mm
thickness 1.5 mm
hope this helps
Post by haydn callow » Sat Mar 27, 2010 10:14 pm
for 50 years now I have always reused the old one, that could mean 20 oil changes on some vehicles....never had a problem.....
Scott & Gillian
Post by Scott & Gillian » Sat Mar 27, 2010 11:21 pm
Cheers for the replys everyone!!
Choices choices!!
kawasaki kid
Post by kawasaki kid » Sat Mar 27, 2010 11:23 pm
If you need to get a replacement washer the one fitted to a Ford Ranger is the same - any Ford dealer should be able to get you one - I fitted one as my van didn`t have a washer fitted when I bought it. :roll:
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
Triple/R
Post by Triple/R » Sun Mar 28, 2010 10:44 am
missfixit70 wrote:Can't tell you the size, but you could just anneal the existing one - http://www.motorcycle.co.uk/Reference-m ... shers.aspx
Nice one Kirsty~we do that with (copper) head gaskets on motorbikes stick em in an oven~that's usually with new ones 8)
Regards Ray & Christine
Post by missfixit70 » Sun Mar 28, 2010 3:31 pm
=D> Usually best to anneal new ones, just to make sure.
