Fuel issue
gasmeter65
Fuel issue
Post by gasmeter65 » Sun Apr 25, 2010 11:44 pm
After getting the gearbox sorted !! Hoorah
I now have a fuel leak. I've noticed a few drips over the past few months, n wasn't too worried. But now it seems to be getting worse.
I have power washed the engine, under tray n everything else, n now is very clean. Missus took her out for a run, when it came back, i could actually smell the diesel. Looked underneath n it has pooled on the undertay, obviously dripping thru the holes onto floor. (Incidently the soaking up material thing came off the undertray so have left it off for now).
Lifted drivers seat up felt all pipes, but can't seem to see where its comming from,
the only possible place is from behind the pump itself, fan / wind blowing it everywhere. This could also be the reason behind poor mileage !!
Any ideas ?
Don't really want to put it into garage, at £45 +vat per hr, if i can help it.
Pete
Re: Fuel issue
Post by mikeonb4c » Sun Apr 25, 2010 11:48 pm
gasmeter65 wrote:After getting the gearbox sorted !! Hoorah
Any ideas ?
Pete
Very possible its the seals on the diesel pump. Unless you want to get involved with fixing it yourself, Wheelquick in Wigan would be worth a visit for diagnosis and mending. Reasonable on charges, only do what needs doing, and know their stuff.
gasmeter65
Re: Fuel issue
Post by gasmeter65 » Sun Apr 25, 2010 11:53 pm
kk ta, will give em a call tomoz,
Do they have the parts in stock normally ? n is it a costly job do ya know !!
The Great Pretender
Re: Fuel issue
Post by The Great Pretender » Mon Apr 26, 2010 12:06 am
Hi Pete, some of these leaks around the pump can be a pain in the a*se to find. The best way I have found is by squirting talc all over the pump (don't use the wife's expensive one). :wink:
To infinity and beyond
dandywarhol
Re: Fuel issue
Post by dandywarhol » Mon Apr 26, 2010 12:21 pm
The Great Pretender wrote:Hi Pete, some of these leaks around the pump can be a pain in the a*se to find. The best way I have found is by squirting talc all over the pump (don't use the wife's expensive one). :wink:
I know a joke about using that method....................................... :lol:
Re: Fuel issue
Post by mikeonb4c » Mon Apr 26, 2010 1:05 pm
gasmeter65 wrote:kk ta, will give em a call tomoz,
If its the seals, parts cost is minimal, but the job can be a bit of a pig (some, like Dandywarhol have successfully done it with the pump in place, but I know of at least one reputable Bongo mechanic who will not do hte job without removing the pump, as access is v. restricted. Shouldn't be megabucks even so, and Wheelquick are usually v. reasonable on labour costs.
gasmeter65
Re: Fuel issue
Post by gasmeter65 » Mon Apr 26, 2010 7:57 pm
Thanx guys, will have another look, maybe try the talc.
Hope the missus doesnt miss it :lol:
gasmeter65
Re: Fuel issue
Post by gasmeter65 » Mon Apr 26, 2010 10:05 pm
Just finished having a good look around, it is the fuel pump unit.
It's against the engine/side of pump, so will need to come off.
Also spotted a fuel/oil leak coming from the turbo, the huge diameter pipe, that looks like an air intake,
But the return oil pipe to the sump is also leaking very slightly. n also the power steer
n also the power steering pipe has been chaffing on something, n has a small split too.
IF IT WASN'T FOR BAD LUCK I'D HAVE NO LUCK AT ALL
Wonder wot else can go wrong !!
Re: Fuel issue
Post by mikeonb4c » Mon Apr 26, 2010 10:47 pm
gasmeter65 wrote:Just finished having a good look around,n it is the fuel pump unit.
It'll all turn out right with luck. Believe it or not people with small hands and good backs have managed to remove the relevant cover and change the O ring on the 'blind side' without removing the pump. But not all garages will agree to do it that way so it is probably a pump off scenario. Give Wheelquick a call. In the meantime, try putting a nice big old cloth on the engine undercover below the pump. It should stay there and will blot up dripping diesel so it doesn't end up on the road [-X
dandywarhol
Re: Fuel issue
Post by dandywarhol » Tue Apr 27, 2010 12:05 am
You really don't need to have small hands to do it - my shovels take size xl motorbike gloves - you loose a bit of skin on your wrists though! :(
gasmeter65
Re: Fuel issue
Post by gasmeter65 » Sat May 01, 2010 1:19 pm
Wheel quick can't do it for another week, so thats one week wasted waiting to hear back.
It is definitely the top seal, so may try it myself. will replace opposite side too
Have stuffed a big old rag but its still leaking , so may have to park it up
Q1 Who sells the seals,
Q2 if it turns out too difficult, can someone pls give me the chaps no in Market Drayton
I'm A49 Oulton Park area
Ta guys
Re: Fuel issue
Post by mikeonb4c » Sat May 01, 2010 8:18 pm
gasmeter65 wrote:Wheel quick can't do it for another week, so thats one week wasted waiting to hear back.
Ta guys
Dandywarhol got agreement from Lawsons Diesels in Edinburgh some time back that they would take orders over the phone and post out the correct (Bosch) O rings for those that wanted them. Not sure what the other seals are but a call to them ought to get you on the right track.
chiefster1976
Re: Fuel issue
Post by chiefster1976 » Thu May 06, 2010 9:07 am
1.DID anyone get the fuel pump O ring seal part numbers yet? My fuel pump is leaking as well on my diesel bongo...
2. Is there a definate on whether these O rings are replaceable WITHOUT taking out the fuel pump???
Racing green with extras!!Self build full side conversion which rocks!!!
dandywarhol
Re: Fuel issue
Post by dandywarhol » Thu May 06, 2010 3:03 pm
http://www.igmaynard.co.uk/bongo/forum/ ... ch#p196104
I fitted the seals with the pump in place - there's a pictorial guide somewhere on here.
Re: Fuel issue
Post by Doone » Thu May 06, 2010 3:07 pm
It's in the members area, LINK HERE
