Lights on warning bleeper
Dan T
Post by Dan T » Thu Apr 29, 2010 1:02 am
Hi, newbie to the forum... I know this has been asked elsewhere, but everyone else seems to have had their problem answered with the simple video. Sadly, my problem is ongoing :(
Reversing beep - check
Key in/ door open beep - Nope
Lights on beep - nope
Connector in place as seen in video, wires all appear to be in tact...
Any other ideas????????
Re: Lights on warning bleeper
Post by missfixit70 » Thu Apr 29, 2010 1:08 am
Are you saying you want them on or off? have you checked the connector in the steering column?
Dan T
Post by Dan T » Thu Apr 29, 2010 2:25 am
Hi Kirsty,
I want them on 'cos I keep leaving my lights on!! Will check steering column connector during daylight hours...
Thank you,
Dan
jaylee
Post by jaylee » Thu Apr 29, 2010 8:26 am
I found i only had a reverse beep when the lights were on, when i disconnected the block under the cowl. :!:
I cut the wire that triggers when the door opens & put a latching switch in line to the side of the fuse box to disable it (for say silent camping.) I also rigged an led in the recess for the ignition key on the cowl to quietly let me know my lights on & to illuminate the key hole in the dark.
Yes, the cab lights still come on when you open the door...
Dan T
Post by Dan T » Fri Apr 30, 2010 5:02 pm
Thank you both for your replies...
Have just got it working again :-) All connectors and wires were in place, but the wire for the lights and key in ignition had broken.
Only a temporary fix at present with insulating tape, but will do a proper fix when the nice weather retruns.
=D>
aitch
Location: in a place far, far away, well Somerset for now!!!
Post by aitch » Fri Apr 30, 2010 6:15 pm
Welcome to the forum Dan T and well done on getting it fixed.
