Hi Flutch solenoidolks
Have been meaning to write this up for 6 months, as my membership lapses in 13 mins i'll do it now !
Problem i had, intermittent dropping out of top gear on a 2wd autobox R4A-EL type
Did the monitoring of the flashing HOLD light using the faheet 24 sept 2008, repeated and consistently came up fault 62 overunning clutch solenoid.
Changed trans fluid to no affect
Got in touch with JP Automatic Transmissions Ltd
Upper Langford
Somerset
They sent me part N194 35 01 Solenoid kit for £76.92
and using print out from pages 411 to 415 used the diagram to help replacing the solenoid pack.
Bit messy taking sump off
then splitting the lowr part of the valve module but then the pack is exposed
unplug solenoids
fit new unit
taking care with the springs which sit between the plates
lots & lots of fasteners to deal with
but i managed it ok
and its still running just fine
Don't be put off doing this task
did take images but not got time to upload
cheers John
Diagnosis and solution to Solenoid Pack Transmission Problem
Re: Diagnosis and solution to Solenoid Pack Transmission Problem
Just cos your membership expires, doesn't mean you can't use the forum - it's free for anyone
Good to know it's not too difficult & it'd be good to see those pics
wasnt aware you could get seperate units! we always swap out the whole pack! useful to know for next time!
Julian
Julian
Neil954
This is the same fault code ours came up with last week, its now up at ADS in Bristol who have quoted £395+vat to fix it.
If I had the time or facilities I would have liked to have a go but my mechanical know how only stretches to the more basic DIY jobs and as were off to the Woodlands meet next weekend I needed to be sure it was sorted properly.
