ATF filler plug
maxwellcooke
ATF filler plug
Post by maxwellcooke » Sun May 09, 2010 12:33 pm
I am needing to refill the Automatic transmission fluid ( gear oil ) following a complete drain, and frustratingly can't find the filler plug. Would really appreciate it if someone could let me know where to locate this.
Many Thanks
Maxwell
redalan1971
Re: ATF filler plug
Post by redalan1971 » Sun May 09, 2010 12:57 pm
you have to pour it down the dip stick tube using a suitable funnel.
maxwellcooke
Re: ATF filler plug
Post by maxwellcooke » Sun May 09, 2010 1:06 pm
did wonder if it would be that, fabulous, thanks for the quick response, gonna take some time then. :roll:
scanner
Re: ATF filler plug
Post by scanner » Sun May 09, 2010 1:27 pm
It's easier and possibly less messy if you can get a large syringe, fit it with a length of windscreen washer pipe or similar and inject it 100ml or so at a time.
Colin H F
Re: ATF filler plug
Post by Colin H F » Sun May 09, 2010 2:02 pm
Yup thats the way to go, even a squeasy washing up liquid bottle will do
