auto box problem
banty
auto box problem
Post by banty » Tue May 11, 2010 8:21 pm
help please i have a 96 bongo when i start it from cold it changes gear perfect with loads of power but after warming up it sticks in 3rd gear with the hold light flashing and will not come right till it is left to cool down agian any pointers
cheers banty
westonwarrior
Re: auto box problem
Post by westonwarrior » Tue May 11, 2010 8:29 pm
You have a problem that is not heat related thats the first thing, its designed to reset if left alone for 30 min or so but will go into limp home mode after 30 of driving and thats what yours is doing
to find what the problem is you need to get the fault code the fact sheet is in the members area on how to get it and read the codes.
or put your location in your profile or give it in a post and we can help a bit better if we know what part of the country you are in
banty
Post by banty » Tue May 11, 2010 8:32 pm
hi i have a mate with a launch 431x code reader will it tell me
cheers banty
westonwarrior
Post by westonwarrior » Tue May 11, 2010 8:33 pm
I dont know I just used a wire on mine
Alacrity
Post by Alacrity » Tue May 11, 2010 10:17 pm
The Launch will not work on the Bongo (or at least mine won't), the vehicle is too early & unsophisticated for a scanner. As westonwarrior says you need to get the fault code(s) out using the procedure detailed in the fact sheet (very simple to do), read the code(s) & if more than one there, note them down then clear them. Now drive the vehicle until the problem re-occurs then re-read the codes, there is every chance you will only have one showing, or at least if you do have more than one you know they are all genuine.
Common codes are TPS, output speed sensor & solenoid issues.
