Post
by helen&tony » Wed Jun 02, 2010 11:43 am
To check the scavenger fan, pull the plug off the sensor by the drivers seat (under the centre console), and short the plug with a paperclip or bit of wire with the ignition on (mine only works with ignition on)...fan goes on.
Plug it back in, and play a salon -type hairdryer( hot one), on the sensor....after a few minutes the sensor will switch the fan on...but you must get the sensor hot.
The radiator fans will go on and off with the aircon. on according to a switchable sensor I have on mine, unless , of course, the engine it hot.
After parking in hot weather for a short while, the scavenger fan MAY go on , but will shut off when you travel 1-2 Km at 30- 40 KPH , as the scavenger fan is only there to flush out hot air rising in the engine bay , which is normally refreshed in motion , by the forward speed...it is only likely to switch the scavenger fan on in slow traffic on a very hot day.
Where I live, we get very hot summers, and I've only had the scavenger fan cut in rarely, after parking.
