Strange Sound from the Steering Wheel
cynfal
Post by cynfal » Thu Jun 03, 2010 8:56 am
Ive started having strange grinding sounds coming from my steering wheel when I drive. Any ideas what this could be and is it safe to drive
Gareth
jaybeeonline
Re: Strange Sound from the Steering Wheel
Post by jaybeeonline » Thu Jun 03, 2010 10:55 am
It maybe the airback clock spring mechanism as I had the same issue with mine.
J
I'll tell you this...
No eternal reward will forgive us now
For wasting the dawn.
Post by francophile1947 » Thu Jun 03, 2010 11:44 am
Check the level of the fluid in the power steering reservoir - mine did the same and the tank was nearly empty, due to the common seal leak :oops:
Post by missfixit70 » Thu Jun 03, 2010 1:14 pm
francophile1947 wrote:Check the level of the fluid in the power steering reservoir - mine did the same and the tank was nearly empty, due to the common seal leak :oops:
Nearly as bad as a gray seal leak, but easily solved with some loperimide laced fish :wink:
FK Mon Sta
Post by FK Mon Sta » Thu Jun 03, 2010 3:05 pm
Mine did that too, turned out to be steering fluid had gone! This might be completely obvious to you, but I had no idea where to find it - it's under the driver's seat.
Good luck
cynfal
Post by cynfal » Thu Jun 03, 2010 4:31 pm
The Power Steering Fluid is full and working OK. Sounds more like bearing wearing away somwhere
Post by missfixit70 » Thu Jun 03, 2010 9:18 pm
Check to see if it's rubbing anywhere on the column & a bit of lube on the UJ's may help - http://www.lushprojects.com/bongopartsm ... mgno=.html
Could be the pinion gears fubar? unlikley though - http://www.lushprojects.com/bongopartsm ... mgno=.html
mister munkey
Post by mister munkey » Thu Jun 03, 2010 9:35 pm
Is it a standard Mazda one or an aftermarket wheel with a Boss?
gmaczbongo
Post by gmaczbongo » Thu Jun 03, 2010 10:12 pm
I have having the same problem.
Going to spray the UJs with loads of WD40 and see if this solves the problem.
I think the UJs are sticking and are pushing the column shaft up towards the plastic cover and causing it to make a "strange sound".
Heat maybe causing the UJs to dry out.
Will check fluid first, after previous posts. Smilie with thumbs up.
gmaczbongo
Post by gmaczbongo » Fri Jun 04, 2010 3:15 pm
Fluid was fine.
Sprayed both joints with wd40 and the steering has been transformed from a notchy tight feel to nice and light.
Gave her a wash and inner clean for being a good bongo.
The upper joint at the pedals has very little clearance space and a tiny amount of seizure will have the joint touching the column down tube.
This noise transfers up the column and leads to the strange noise.
I am sure it is the upper joint that is the problem.
A bit of newspaper underneath and a good spray will give you a new feel to the steering.
I came back a day early because I thought my steering was about to give up. \:D/
