Bulwell Bongoleers
- Tribal Elder
Post
by Bulwell Bongoleers » Sat Jun 05, 2010 3:09 pm
well just been out in the Bongo and my remote central locking has started playing up!
when you press the fob it will only unlock or lock the drivers door the other doors have to be opened by the key or by hand! I'm assuming this is a factory fitted one as was on when i bought the bongo,Any ideas what could be the problem have checked both fuses and they are both ok.
Andy
Manda & Andy
Post
by Northern Bongolow » Sat Jun 05, 2010 3:13 pm
never delved onto this myself,but uneducated guess maybe door wiring loom maybe,where the hinge is the wires tend to break.
hello by the way
321Away
- Tribal Elder
Post
by 321Away » Sat Jun 05, 2010 3:23 pm
Agree, wiring loom between door n body, do the other doors lock/unlock when u manullay activate locking, by moving knobbly up n down? if not then definitely wiring loom
Bulwell Bongoleers
- Tribal Elder
Post
by Bulwell Bongoleers » Sat Jun 05, 2010 7:38 pm
After an afternoon of stripping the door down, I have found the central locking to be after market system.(its part of the alarm) I did strip the driver's door wiring loom and found 3 broken wires, repaired these but it still was not working. I dont think these broken wires had anything to do with the actuator as the wires for this were totally seperate from the loom and was soldered into connections behind the dash. If you operate the knobbly it does not operate the other doors!
Manda & Andy
dandemann8
Post
by dandemann8 » Sat Jun 05, 2010 7:41 pm
Hi, I had this last week and found out that my LB voltage was down so after a recharge all's well finger's crossed
Bongo no more........... ;-(
Bulwell Bongoleers
- Tribal Elder
Post
by Bulwell Bongoleers » Sat Jun 05, 2010 8:04 pm
dandemann8 wrote:Hi, I had this last week and found out that my LB voltage was down so after a recharge all's well finger's crossed
I do have a LB fitted by a willington kit, Bongo tends to stand most of the week but unlocked and locked fine first thing this morning, just played up this afternoon when nipped out to the shops.I will check LB voltage and check its charging ok.
Manda & Andy
You've Been Bongod
Post
by You've Been Bongod » Sat Jun 05, 2010 8:07 pm
if have no luck with that check the relay behind the dash as i had this trouble with an old bongo i had
