Airlift Suspension
Airlift Suspension
Hi, my Tintop is lowered and only has approx 2 inches of rear suspension travel. As you may guess it bottoms out frequently. After over two years I decided to oreder and fit some Airlift Suspension bags from Matt Savage. Took 2 hours to fit pretty straigt forward but my what a difference in the ride....I can go over speed ramps without bottoming out it's great...was considering going back to stsndard size springs but no chance now...I would recommend thses totally...Georgey...p.s. see you all at Stourport...
- Simon Jones
Re: Airlift Suspension
Out of interest, how much did it cost?
Here you go Simon - http://www.mattsavage.com/acatalog/copy ... rings.html - finally got around to fitting mine
Didn't use the spring compressors, went old school & dropped the axle, found some more bits to waxoil in the process
Haven't found my ideal position for the valves yet though & didn't take any pics, but it's common sense nutsn bolts stuff. I'll let you know what difference it makes at the bash after a heavily loaded run .
- Simon Jones
Cheers for that Kirsty. I'm very tempted to get a set as Bob was showing me his setup at Southern Softies & he was very impressed with the improved handling.
- dandywarhol
If its any help, I put the pipes onto a tee piece and located the valve at the rear of the doorstepmissfixit70 wrote:Here you go Simon - http://www.mattsavage.com/acatalog/copy ... rings.html - finally got around to fitting mineDidn't use the spring compressors, went old school & dropped the axle, found some more bits to waxoil in the process
I'm thinking bringing it up to the cab, pressure gauge & compressor out of one of those booster pack jobbies that I've got lying around as the battery went on itdandywarhol wrote:If its any help, I put the pipes onto a tee piece and located the valve at the rear of the doorstepmissfixit70 wrote:Here you go Simon - http://www.mattsavage.com/acatalog/copy ... rings.html - finally got around to fitting mineDidn't use the spring compressors, went old school & dropped the axle, found some more bits to waxoil in the process
- dandywarhol
Lot of extra hassle methinks - once you've found the suitable pressure (17 psi for an unconverted one for me) there's little to adjust except for a really heavy load on board and you can pump it up 4 psi...................
Very interesting!georgey wrote:Hi, my Tintop is lowered and only has approx 2 inches of rear suspension travel. As you may guess it bottoms out frequently. After over two years I decided to oreder and fit some Airlift Suspension bags from Matt Savage. Took 2 hours to fit pretty straigt forward but my what a difference in the ride....I can go over speed ramps without bottoming out it's great...was considering going back to stsndard size springs but no chance now...I would recommend thses totally...Georgey...p.s. see you all at Stourport...
If you get em ordered quick, I'll have Freewheeler's spring compressors with me to return to him, shouldn't take long to do with a field full of volunteers
I quite like the idea of these with the compressor built in - drive around in comfort, then park up, let the air out and look cool
...I can see another mid life crisis comming on
