Japanese Towbar socket
paulyg
Post by paulyg » Sat Jun 12, 2010 8:45 pm
my recently imported "Special Edition" Ford Freda came with a towbar, however the electric socket is not compatible with the 7 pin socket on the lighting board I have just bought, it does have 7 pins but is slightly larger and they all point out, rather than the in & out configuration on UK purchased ones. Is there an adapter available or has anyone switched it for a compatible socket without having the whole thing rewired? :cry:
dobby
Re: Japanese Towbar socket
Post by dobby » Sat Jun 12, 2010 9:02 pm
That's a rarity!
Best to feel good you got a towbar and just rewire a new socket to suit.
Should be an easy job.
scanner
Post by scanner » Sat Jun 12, 2010 10:12 pm
Just swapping the socket on the end to a Euro one shouldn't cost much - BUT the colour coding of the wires may not be the same.
This is how they should be wired, if the colours aren't the same you'll have to sort out which is which with either a voltmeter or even just a bulb.
http://www.google.co.uk/imgres?imgurl=h ... CCMQ9QEwAA
mikexgough
Post by mikexgough » Sun Jun 13, 2010 8:47 am
I agree with the previous posters........... Now I have found a wiring diagram for Japanese 13 Pins...... You would need to get some translation to it to get the colours etc but it could/might help......... http://translate.googleusercontent.com/ ... r7c8ks_cBA
scanner
Post by scanner » Sun Jun 13, 2010 12:05 pm
Wow! their Bongos even have space to store a spare wheel for the trailer. :lol:
paulyg
Post by paulyg » Wed Jun 16, 2010 9:36 am
Thanks all for the helpful info, I am going to have a go, but as my electrical knowledge isnt that great I will have an idea of what to say with the local bongo garage.
lpgimports
Post by lpgimports » Wed Jun 16, 2010 8:49 pm
I seriously recomend having the towbar checked over by someone who knows what they are talking about in respect of towing, the Japanese dont really have a caravan culture, and towbars are ussually for small trailers generally a small boat, not a big caravan as we like to tow here in UK.
Wiring in a standard socket, should take less than an hour I have done it in less than 30 mins, I would avoid going near the existing at all and pickup most connections behind the drivers rear light earth from the body, and passenger side lights from the loom as it goes accross the rear of the bongo under the plastic step trim.
Paul
paulyg
Post by paulyg » Thu Jun 17, 2010 2:56 pm
Hi Paul,
thanks for that, I definitely will get the towbar checked out, something I had not thought of, at the mo I just want the electrics for a lighting board for bikes, but have plans for a trailer/ jetski and even possibly moving a caravan from seasonal pitch.
Pauly G
Scott
Post by Scott » Thu Jun 17, 2010 3:05 pm
paulyg wrote:Hi Paul,
Pauly G
You can easily work out what the wiring does with a multimeter or 12v tester, just get someone to help by turning on the indicators, lights, brakes etc and mark the wires up, then attach the new socket to the relevant wires :wink:
The user formerly known as csmcqueen ;)
スコット
