Injection Pump Plunger lift
Tripewriter
Post by Tripewriter » Wed Jun 16, 2010 2:50 pm
Does anyone out there (with a workshop manual?) know the setting for the Pump Plunger lift. EG. The Montego Turbo Diesel is 1.20 m/m plunger lift, (same pump)
The plunger lift is measured using a Dial Indicator with an extension inserted into the pump through the access hole in the centre of the distribution end of the pump.
321Away
Re: Injection Pump Plunger lift
Post by 321Away » Thu Jun 17, 2010 9:23 am
according to the book 1mm+/-0.5mm.
Julian
Tripewriter
Post by Tripewriter » Thu Jun 17, 2010 5:21 pm
Many Thanks for that. :D
