radio
baronweetman
radio
Post by baronweetman » Thu Jun 24, 2010 3:30 pm
Looked everywhere else but can't find it. How does the radio come out please?
[b]la connaissance exacte du passé, en éclairant le présent, vous permettra d'agir sur l'avenir[/b]
lpgimports
Re: radio
Post by lpgimports » Thu Jun 24, 2010 3:36 pm
If its a standard radio either side of it will be two vertical strips about 5mm wide, these lift out with a small flat blade screw driver to reveal some holes, radio removal keys/tools slide down these and then you lever to release their grip to remove. The keys are the same as used on most late 80's 90's Fords, most car accessory/audio places sell them for a couple of pounds, you can do it with a number of small screwdrivers but can be awkward.
Paul
TechnoTurkey
Re: radio
Post by TechnoTurkey » Thu Jun 24, 2010 3:52 pm
I thought you were on the sofa watching the football at 3.30 yesterday Paul!
A good way of getting the radio out if you haven't got the proper tool is to make a tool using a metal coathanger. Chop two 4" sections off, fashion them both into a U shape, with the straight sides being parallel and the same distance apart as the stereo holes and they will release the clips when inserted.
They should each look like:
Member 10,000!
1997 Green AFT 4x4 2.5TD Auto Bongo
baronweetman
Re: radio
Post by baronweetman » Thu Jun 24, 2010 4:42 pm
Thanks for that you two. It is now done and the new one in. Thanx again. Bruce
dunslair
Re: radio
Post by dunslair » Thu Jun 24, 2010 4:58 pm
And pop the glove box out so you can get yer nogin in to see what you are doing :wink: (drop forward and squeeze sides in to release)
Scott
Re: radio
Post by Scott » Thu Jun 24, 2010 9:20 pm
dunslair wrote:And pop the glove box out so you can get yer nogin in to see what you are doing :wink: (drop forward and squeeze sides in to release)
Removing the glove box is great, there is loads of room behind there to get your mitts behinds the stereo :D
The user formerly known as csmcqueen ;)
スコット
