Engine temperatures
- widdowson2008
Engine temperatures
From data collected, the mean temperatures after the system has gone through the warming up phase and sort of stabilised are as follows:
Head - 89 degrees C
Block - 65 degrees C
These are coolant temperatures.
Are these what you can reasonably expect?
Tests are ongoing, but the data so far seems to be settling down to the above figures.
Head - 89 degrees C
Steve
- dandywarhol
Re: Engine temperatures
Sounds fine to me - a 1 bar pressure cap blow off will allow the temp to get to around 120 C before letting off steam - that allows 30 deg to play with up hills and down dales
- widdowson2008
Thanks Dandy.
Next question -
As I understand it (and I may be wrong) there are two totally different environments in a diesel engine, each requiring its own ideal operating temperature.
1 - The head, which requires an op temp high enough to detonate the fuel
2 - The block, which requires an op temp within the lubricating oil parameters
Would I be correct in assuming that the cooling system has been designed to maintain the temperatures currently being experienced in the data (89 head, 65 block) for the above reasons? or are there more?
I need to take this slow cos I need to understand it
Next question -
Steve
- dandywarhol
I would't think its anything more than natural upwards convection of coolant and the fact that the power explosion is in the piston bowl causing the temp differences. The mass of metal around these components will dictate the designed temperatures
- widdowson2008
Grrrrrrrrrrrrrr.
I think I need to rephrase the question (or take a step backward.)
upwards convection of coolant? Thought it was pumped throughout?
mass of metal around these components will dictate the designed temperatures? Wouldn't the ideal temperature of the flashpoint/detonation point be the design criteria for the head?
Not argueing at all - just asking questions.
What I am trying to nail down is
1 - What generates the heat (combustion + friction?)
2 - How much cooling goes on in each section of the system (between components.)
Steve
- dandywarhol
Pump ASSISTED - heat conducts through the cylinder walls as a result of combustion and friction (as you saidwiddowson2008 wrote:Grrrrrrrrrrrrrr.I think I need to rephrase the question (or take a step backward.)
Not argueing at all - just asking questions.![]()
The cylinder temp is produced by the compressed air - needs to be at least 500 deg.C to spontaneously burn when the diesel is injected into the pre-combustion camber, so I guess a combination of water jacket design/head design/cooling system ancilliaries design will also contribute to the ideal controlled temperature
- widdowson2008
Thanks for the lesson Dandy
Knew things got hot but 500deg.C
Bloody hell
Steve
- dandywarhol
Thats just to start the burn - around 2000 deg.C when combustion takes place for that split second - now y'know why the cooling system needs to be right
- widdowson2008
FRIGHTENING!!dandywarhol wrote:Thats just to start the burn - around 2000 deg.C when combustion takes place for that split second - now y'know why the cooling system needs to be right
So at 1500 RPM, that's 25 combustions of 2000 deg.C EVERY SECOND.
Steve
- widdowson2008
or is that 50 combustions? Whichever, its a lot banging going on.widdowson2008 wrote:FRIGHTENING!!dandywarhol wrote:Thats just to start the burn - around 2000 deg.C when combustion takes place for that split second - now y'know why the cooling system needs to be right
So at 1500 RPM, that's 25 combustions of 2000 deg.C EVERY SECOND.WARALOT
Steve
- dandywarhol
50
Now imagine an F1 engine at 1266 bangs/sec.
