I am looking to buy a Mazda Bongo freetop.
i am getting different information on the wax oil (undersealing) of vehicles imported from Japan. i had understood that it was fairly necessary but one dealer insists others are doing it to cover up rust etc. Help please! Also any other typical problems I should be looking out for?
regards
Louise
Hello all Newbie here!
Moderator: Ian
Louiseupnorth
Re: Hello all Newbie here!
hi and welcome.
you are right to be concerned about waxoiling but.
i have just bought one that has been in the country for three years,never waxoiled,and was showing slight signs of surface rust.but at least i could see what was there.it has now been done.my point is,i like to see if its bad,and not hiden under a lovely oily covering.the other side of that is that if its been done as it came in to the country it SHOULD be ok.rust around the rear wheel arches will give you some clues.
the other main prolem area is the cooling system.make sure you take someone who knows bongos with you,when you go to view.there are lots of good peeps in west yorks who could help.
i have pmd you .
i have pmd you .
Eyup louise~up~northLouiseupnorth wrote:Hi
regards
Louise
So what i'm saying is it definitely wants waxoiling but if you did buy one not done it would be advisable to let a specialist do it or diy to do it properly.
Regards Ray & Christine
