Which one is the dash ABS light..??
steveyd
Post by steveyd » Wed Jul 21, 2010 11:36 am
My ABS doesnt seem to be working -I've been following another recent thread on ABS problems and got some useful info on which fuses etc to check. All my fuses are ok, yet I get no yellow light on the dash when I turn the ignition on. My ABS doesnt seem to be working so I want to know if the bulb on the dash has gone, so I can work on from there. Can I assume the light comes on when the ignition comes on - like my other cars of this vintage?
Before I dismantle everything, and as I've never seen the light in the 6 months I've had Noodle, whereabouts in the dash cluster is the light i.e. next to the glow plug light?? Is it yellow? I've tried shining a bright torch but no luck..
I def. have ABS as I have the pump and the (intact) fuses!
cheers,
Steve
Re: Which one is the dash ABS light..??
Post by missfixit70 » Wed Jul 21, 2010 2:25 pm
Far right above the roof opening light.
steveyd
Post by steveyd » Wed Jul 21, 2010 4:03 pm
thanks - will check tonight!!
Steve
steveyd
Post by steveyd » Tue Jul 27, 2010 10:19 am
cheers - found it, or rather the hole where the bulb should go.. some scumbag has obviously removed it to hide the problem - either at the dockside in Japan or when being prepped for sale here..
I'll look up other posts on finding ABS problems.
Steve
