Are you following me ???
Its unlikely both motors are duff, so the obvious culprit could be the drivers door wiring loom.
So how to take the door apart ?
Does the door panel just pop off ?
Am i likely to bugger up any clips in doing so ?
Another option, has anyone ever just had the windows stick through no use ?
My new bongo was sat for 12 months under a sticky sappy tree, and when i got it it took days to get it all off the paintwork, so could the glass just be stuck solid to the rubber trims ?
HELP, my Bongo is a Springer transporter, and having no windows is not an option.
