Post
by rita » Fri Aug 06, 2010 1:21 pm
Has anybody used a Pela (or similar type hand pump)to Vacuum change coolant.
I would seem that a few of the Rover people use a Pela 6000 to carry out this function using a Rubber Bung/T-piece and a couple of clamps.
Dive Dive Dive
Post
by missfixit70 » Fri Aug 06, 2010 1:27 pm
That all looked a bit too Heath Robinson to me, but it'd be interesting to see if it works & how much time/aggro it takes
Post
by francophile1947 » Fri Aug 06, 2010 1:41 pm
I would have thought that a Pela pump could only create enough vacuum to fill itself - once full of coolant, there is no vacuum left. Can't see how it can be done in stages either
- probably totally wrong though
munroman
- Tribal Elder
Post
by munroman » Fri Aug 06, 2010 2:15 pm
mikexgough
Post
by mikexgough » Fri Aug 06, 2010 2:19 pm
Looks okay to me........ will take longer than 5 minutes....
but the physics is all there and enough "suck" too....and the 75 has an 8.2 litre cooling system which kind of addresses the coolant amount........better ask a lady I know if she has some rubber bungs in her Lab of the right size for a Bongo.... if it works.....then I must get some labels made with Mazda Bongo on them.....ready for ebay....
Post
by teenmal » Fri Aug 06, 2010 4:12 pm
francophile1947 wrote:I would have thought that a Pela pump could only create enough vacuum to fill itself - once full of coolant, there is no vacuum left. Can't see how it can be done in stages either
Hi John,
You only start the vacuum process when the coolant has been drained from the system.
Mal.
mikexgough
Post
by mikexgough » Fri Aug 06, 2010 6:44 pm
Should work with the same technique as the Rover as the engine has the same set up as a Bongo with the Thermostat on the return side of the cooling system....
westonwarrior
Post
by westonwarrior » Fri Aug 06, 2010 6:58 pm
would the vacuum causing the pipes to collapse cause extra stress on old and weakened pipes increasing the chances of splitting?
I don't think I would try it on old pipes
mikexgough
Post
by mikexgough » Fri Aug 06, 2010 7:05 pm
On old pipes I guess that could be an issue but then of course the system would be empty and leaks would show up and a plus point is then, you can replace the defective hoses......
mikexgough
Post
by mikexgough » Fri Aug 06, 2010 7:06 pm
mikexgough wrote:On old pipes I guess that could be an issue but then of course the system would be empty and leaks would show up as air would be introduced to the system and inflate the rubber hoses and a plus point is then, you can replace the defective hoses......
