oily spots on the back of bongo
tomheaney99
Post by tomheaney99 » Wed Aug 25, 2010 11:13 am
does anyone else get oily spots over the back of the bongo? Mines been doing this for some time now? It also gets really soooty on the back tooo. My exuast is a twin exhaust which is angles slightly up away from the ground.
any ideas?
tom
Re: oily spots on the back of bongo
Post by teenmal » Wed Aug 25, 2010 12:00 pm
tomheaney99 wrote:does anyone else get oily spots over the back of the bongo? Mines been doing this for some time now? It also gets really soooty on the back tooo. My exuast is a twin exhaust which is angles slightly up away from the ground.
any ideas?
tom
Hi tom,
Do you use veg oil?
It could also mean that your inlet manifold is needing a clean out.
Mal..
tomheaney99
Post by tomheaney99 » Wed Aug 25, 2010 12:26 pm
i used to use veg oil about 3 months ago and that's when it 1st started however stopped using it and i've done a fair few trips (scotland etc) since then and it still does it? the soooting up is thick all over the back too still ...?
tomheaney99
Post by tomheaney99 » Wed Aug 25, 2010 12:36 pm
question - :)
where is the inlet manifold?? ha
tom
Post by teenmal » Wed Aug 25, 2010 12:49 pm
Hi tom,
The inlet manifold http://www.lushprojects.com/bongopartsm ... mgno=.html
This is on the off-side of the engine(drivers side).To clean it out properly it would need to be removed .
Mal..
tomheaney99
Post by tomheaney99 » Wed Aug 25, 2010 12:57 pm
thanks mal for quick response will give it a go :)
Post by francophile1947 » Wed Aug 25, 2010 1:02 pm
Your exhaust won't help, as it's directing the exhaust gases into the turbulence you get around the back of the van, instead of away from it - downward pointing would be better. This turbulence sucks all the muck onto the van :roll: Just look at the back after driving on a wet road - they don't fit rear wipers for nothing :lol:
gmaczbongo
Post by gmaczbongo » Wed Aug 25, 2010 5:14 pm
Are you parked against a wall etc when you start it up.
Oily spots could just be the condensation when you start the van.
tomheaney99
Post by tomheaney99 » Wed Aug 25, 2010 5:28 pm
nah i even washed it and a trip to nrth yorkshire - spots appeared again. got them alot when i used to run it on veg oil but stopped it because of the dirty back end (hehe) however still gets oily deposits :/
gmaczbongo
Post by gmaczbongo » Wed Aug 25, 2010 5:32 pm
I meant to say, change the fuel filter.
Cheapest option, ebay and others have cheap filters, cheap by price and not by quality.
tomheaney99
Post by tomheaney99 » Wed Aug 25, 2010 6:41 pm
filter was changed only 4 mnths ago?
mister munkey
Post by mister munkey » Wed Aug 25, 2010 7:14 pm
What about the air filter?
Could be running rich, tends to soot up a bit.
tomheaney99
Post by tomheaney99 » Wed Aug 25, 2010 7:23 pm
ive put a K&N air filter in just recently?
gmaczbongo
Post by gmaczbongo » Wed Aug 25, 2010 8:21 pm
Filter 4 months. Veggie 3 months.
"It all stated when veggie was used".
Tripewriter
Post by Tripewriter » Sat Aug 28, 2010 8:51 am
It could be residue in the exhaust if exhaust is usually smoke free!
