fitting extra fuse box
bobngo
Post by bobngo » Mon Sep 06, 2010 5:03 pm
i intend to fit an extra fuse box to the removable panel just below the steering wheel ,but i need a source of power, for both "always on" and " on with ignition only "
so where can i get this power off the main fuse block (near right leg) WITHOUT GOING THROUGH THE FUSE BOX
or what colour are the wires etc
or for on with ignition only , can i get it off the ignition switch etc
this will be for some gizmos and gadgets i want to fit, and do,nt want to tap into existing fused lines as bongo wiring looks so thin, and running at it maximum capable capacity already .
Re: fitting extra fuse box
Post by haydn callow » Mon Sep 06, 2010 5:15 pm
Go to the "normal" fuse box by your right knee...remove the flap....remove 2 x screws.....pull the box forward and get to the back, top row.....2 "BIG" thick wires which are the main feeds to the box.
One is ignition on live and the other permanant live.
Post by g8dhe » Mon Sep 06, 2010 5:31 pm
The colours are here;
That's White with Red stripe +12 volt permanent supply,
Red with Black stripe +12 volt ACC supply,
Blue with White stripe +12 volt IG2 supply.
bobngo
Post by bobngo » Mon Sep 06, 2010 8:23 pm
haydn,g8dhe , fantastic ,exactly what i wanted to know, and the speed of reply ,well!!!
thank you very much
dobby
Post by dobby » Mon Sep 06, 2010 8:27 pm
Have you sourced the extra fusebox yet. I did mine recently and it was a real P in the A to loop in and out for the feeds, couldn't get a bus bar fuse board anywhere.
bobngo
Post by bobngo » Mon Sep 06, 2010 8:35 pm
dobby ,yes i,ve got some (2) with 4 positions per block, from my local car spares shop,off the shelf , complete with whatever fuses i wanted.
4 in,s and 4 outs per block, i will join all the in,s to make a common rail, then through individsual fuses to each device
think they take any fuse up to about 30+ amps , like the normal type fuse
can,t remember the price but was cheap
bobngo
Post by bobngo » Mon Sep 06, 2010 8:38 pm
i tried to print this set of posts, but they will not print ,tried to use " print view " but nothing happens .
how can i print from this forum ?????
Post by g8dhe » Mon Sep 06, 2010 8:47 pm
You select Print View and then in your Browser print the resulting pages, File, Print Preview - make choices on format - hit print.
