Hose, steel pipe, and clip identification
widdowson2008
Post by widdowson2008 » Wed Sep 08, 2010 8:07 pm
As part of the cooling fact sheet, I produced the following from a list provided by Kirsty from lushproject drawings in the hope it will help folk identify problem hoses quickly. Not quite finished yet (numbers from list to add to images) but I think you will get an idea of where I'm going with this.
Not animated, sorry. :oops:
Hose, pipe and clip list
Main hoses - near side (passenger)
Main hoses - off side (driver)
Heater hoses - near side (passenger)
Heater hoses - off side (driver)
Constructive critism welcomed.
Steve
mister munkey
Re: Hose, steel pipe, and clip identification
Post by mister munkey » Wed Sep 08, 2010 8:12 pm
Great piece of work but kinda hard to see, a bit misty.
Should I go to Specsavers?
munroman
Post by munroman » Wed Sep 08, 2010 8:15 pm
Hi Steve, thanks for all the work you are doing for fellow owners!
Firstly, could you make the drawings bigger for old eyes like mine! - I know it it most likely a forum thing, but it would be good to know that a factsheet was in A4 for example.
Secondly, for similar reasons, can you make the part numbers darker, black and bold for example?
Thirdly, and perhaps Haydn can help, would it be possible to give sizes for the hose clips, I am an exponent of using the OEM constant pressure clips, but for emergencies it would be good to have proper sized spares.
Keep up the good work, it is appreciated! =D>
widdowson2008
Post by widdowson2008 » Wed Sep 08, 2010 8:27 pm
mister munkey wrote:Great piece of work but kinda hard to see, a bit misty.
Quality loses out through photobucket - sorry. :oops: If you pm your emai address I'll send the original pdf's - much easier (and clearer) to read. :D
Steve
widdowson2008
Post by widdowson2008 » Wed Sep 08, 2010 9:25 pm
muHATDNHAYDN!!!!!!!!!?nroman wrote:Hi Steve, thanks for all the work you are doing for fellow owners!
Firstly, could you make the drawings bigger for old eyes like mine! - I know it it most likely a forum thing, but it would be good to know that a factsheet was in A4 for example.The forum pics are as big as allowed. but the factsheet WILL be A4.
Thirdly, and perhaps Haydn can help, would it be possible to give sizes for the hose clips, I am an exponent of using the OEM constant pressure clips, but for emergencies it would be good to have proper sized spares.HAYDN!!!!!!! - HELP
pm+email sent
Steve
widdowson2008
Post by widdowson2008 » Thu Sep 09, 2010 12:51 pm
munroman wrote: Firstly, could you make the drawings bigger for old eyes like mine! Pics are as big as forum allows
factsheet was in A4 for example. Factsheet is A4
Secondly, for similar reasons, can you make the part numbers darker, black and bold for example?Done
Thirdly, and perhaps Haydn can help, would it be possible to give sizes for the hose clips, I am an exponent of using the OEM constant pressure clips, but for emergencies it would be good to have proper sized spares.Not heard back from Haydn yet
Following suggestions from munroman, mrmunkey, et al about clarity, this may be better.
THE NUMBERS HAVE NOT YET BEEN CHECKED AND CONFIRMED. I THINK THEY ARE CORRECT BUT NEED VERIFICATION
and this one
Steve
widdowson2008
Post by widdowson2008 » Thu Sep 09, 2010 3:12 pm
Main hoses - Offside
Heater hoses - far side
Steve
Post by Northern Bongolow » Thu Sep 09, 2010 3:39 pm
:D :D :D :D =D> =D> =D> =D>
steveyd
Post by steveyd » Thu Sep 09, 2010 4:18 pm
Absolutely excellent! And perfect timing too - I need the 2 rear heater hoses and its confusing on the original diagrams as they appear on different pages!
Thankyou!
Steve
widdowson2008
Post by widdowson2008 » Thu Sep 09, 2010 6:56 pm
I floated this set of pics to see if they would be useful. Didn't mean for folk to jump in there and use it. :shock:
THE NUMBERS HAVE NOT YET BEEN CHECKED AND CONFIRMED. I THINK THEY ARE CORRECT BUT NEED VERIFICATION. I NEED SOMEONE TO DO THIS FOR ME, IDEALY BEFORE FOLK START USING IT. ANY TAKERS?
PERHAPS ONE OF THE MODS COULD ISSUE A HEALTH WARNING UNTIL CONFIRMED.
Steve
westonwarrior
Post by westonwarrior » Thu Sep 09, 2010 7:15 pm
I think the health warning you have just given is perfect.
Great job
Post by haydn callow » Fri Sep 10, 2010 7:21 am
15-186 = 2 x 44
15-183 = 2 x 44
15-184 = 2 x 44
15-185 = 2 x 44
15-227 = 2 x 28
15-188 = 2 x 18
15-261 = 2 x 30
15-381 = 2 x 18
61-211 = 2 x 28
61-212 = 2 x 28
61-213 = 2 x 28
61-214 = 2 x 28
61-211A = 2 x 28
61-212C = 2 x 28
61-213A = 2 x 28
13-539A = 2 x 18
13-546 = 2 x 18
= 8 x 44
=16 x 28
=2 x 30
= 2 x 18
PLUS 6 x 18
All the above from a list sent to me by Kirsty
I'm not allowed to mention that I have obtained a supply of the NORMA constant pressure hose clamps that will cover all the above sizes.
12-20mm
20-32mm
32-50mm
widdowson2008
Post by widdowson2008 » Fri Sep 10, 2010 10:34 am
Thanks Haydn. (and Kirsty for suppling the original clip list)
Checked through the list and it confirms the sketches.
Checked through the sketches AGAIN and I can now confirm that the HEALTH WARNING no longer exists. THE NUMBERS ARE CORRECT.
Steve
helen&tony
Post by helen&tony » Fri Sep 10, 2010 10:47 am
Mr Munkey....Misty????...Ah...I remember...Gorillas in the Mist...
Steve
First rate...as usual........after all that work, there'll no doubt be a request in the stuff wanted section for a toupee and fingernails...how can you do all that without tearing your hair out and chewing your nails !!!
widdowson2008
Post by widdowson2008 » Fri Sep 10, 2010 10:54 am
Helen - Nails get nibbled a bit but I have absolutely no problem in the hair department - grows like twitch.
ps. Just asked a member to check out the sketches and numbers for me just to make absolutely sure it is all 100% correct, then I can put this project to bed. :D
Steve
