Hi All,
Can anyone tell me what dash bulbs i should purchase as the middle dial (speedo) is white and the ones either side are greeny colour , just looks a bit weird and as i am having the plasma dials fitted i would like them all to be the same.
Many thanks in advance......Harry
What bulbs should i use ?
chakota
- You've Been Bongod
Re: What bulbs should i use ?
if your having the plasma dials fitted leave the bulbs as they are as the dials come with wire to connect and the self illuminate
chakota
You've Been Bongod wrote:if your having the plasma dials fitted leave the bulbs as they are as the dials come with wire to connect and the self illuminate
Many thanks for that info ... i got the kit but i assumed you used the bulbs already fitted
Once again ....... your a star!
Harry, you use the bulbs that are already there, they light up the needleschakota wrote:You've Been Bongod wrote:if your having the plasma dials fitted leave the bulbs as they are as the dials come with wire to connect and the self illuminate
Many thanks for that info ... i got the kit but i assumed you used the bulbs already fitted![]()
or change them for LED's I used red in mine
The user formerly known as csmcqueen
スコット
スコット
