Drop Link Rubber Bushes Front and rear.
Tripewriter
Post by Tripewriter » Sat Sep 18, 2010 1:24 pm
The latest MOT resulted in a pass but I was advised to replace the rubber bushes on the links to the anti roll bars front and rear. Has anyone done this is there an idiots guide?
mister munkey
Re: Drop Link Rubber Bushes Front and rear.
Post by mister munkey » Sat Sep 18, 2010 2:37 pm
Have a look at this thread . . . . .
Its pretty informed & with pictures too!!
http://www.igmaynard.co.uk/bongo/forum/ ... Drop+links
You've Been Bongod
Post by You've Been Bongod » Sat Sep 18, 2010 7:13 pm
quite easy to do just remeber to wd40 the nuts and bolts prior to doing the job
2 bolts on rear bushes
2 nuts on front bushes
either 17 or 19 mm
trolley jack to take the weight
321Away
Post by 321Away » Wed Sep 22, 2010 11:50 am
? both front and rear bushes and rear drop links are all 14mm, original front anti-roll bar drop links are 17mm nut, and may need a 19mm spanner on the back, replacements are usually the reverse, 19mm nut and 17mm on the back.
Julian
mobilecat
Post by mobilecat » Wed Sep 22, 2010 3:44 pm
Its a speed bump thing - its the only tweek mine has needed for the last two MOTs and I would guess it will be there same time next time (although hopefully someone else will own it then).
wishmaster
Post by wishmaster » Sat Sep 25, 2010 6:40 pm
Just changed our front ARB bushes and drop links :) makes a hell of a difference to the ride :D looking at the old ones they were due for replacing tho :roll:
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
mikexgough
Post by mikexgough » Sat Sep 25, 2010 6:45 pm
wishmaster wrote:Just changed our front ARB bushes and drop links :) makes a hell of a difference to the ride :D looking at the old ones they were due for replacing tho :roll:
Always best to replace all the parts connected along the Anti Roll Bar ...... :wink: otherwise if you just change the bushes or drop links alone......you will be doing the other parts as another job a week or so later.....
nfn
Post by nfn » Sat Sep 25, 2010 6:58 pm
I agree with Wishmaster -- if your bongo's suspension bushes and droplinks are genuinely knackered, replacing them makes a huge difference to ride, noise over bumps, and handling. It's not that hard a job either, as long as what's on there isn't too rusty. If so, a can of Plus Gas dismantling spray should help. WD40 isn't as good for getting rusted nuts and bolts off -- I think the effect of WD40 is mostly psychological.
