Starting Grief
Hwilliams
Starting Grief
Post by Hwilliams » Sun Sep 19, 2010 7:02 pm
Hi. New to this techmalarckie! Need help/ideas please.
Bongo Diesel. All was fine. After lack of usage wouldnt start. Fully reCharged Battery and checked. Told all was fine with it.
Charge and discharge all ok. Barely turns the engine as though drained. Wont fire.
Cheers.
wonkanoby
Re: Starting Grief
Post by wonkanoby » Sun Sep 19, 2010 7:16 pm
reads like a dodgey battery to me though still
munroman
Re: Starting Grief
Post by munroman » Sun Sep 19, 2010 7:27 pm
wonkanoby wrote:reads like a dodgey battery to me though still
Agree, plus check all the leads are clean and tight, might be worth taking off the battery terminals and cleaning with some fine sandpaper, also clean the inside of the battery clamps.
Make sure the clamps are tight.(I think someone traced their problems to a loose clamp.
Check that the battery earth and engine earths are in good condition, as they may have corroded whilst the Bongo was laid up.
mikexgough
Re: Starting Grief
Post by mikexgough » Sun Sep 19, 2010 7:40 pm
Sound advice and always start (excuse the pun) with the basics....Clean up terminals and check the tightness of the clamps......... Could still be a cell on it's way out in the battery....and if your unsure of battery age or if it has a JIS number.....bin it ...
321Away
Re: Starting Grief
Post by 321Away » Mon Sep 20, 2010 11:45 am
could be starter motor related?
Julian
wonkanoby
Re: Starting Grief
Post by wonkanoby » Mon Sep 20, 2010 2:29 pm
not normally
they usually default to clicking
not turning over slow when the contacts wear
wormey
Re: Starting Grief
Post by wormey » Mon Sep 20, 2010 6:33 pm
Hwilliams wrote:Hi. New to this techmalarckie! Need help/ideas please.
Cheers.
Where are you, Sounds like battery to me.
Daz and debs
bobngo
Re: Starting Grief
Post by bobngo » Mon Sep 20, 2010 8:11 pm
if you are going to clean the battery terminals,
disconnect negative terminal ( -)first ,then the positive (+)last
when you reconnect ,reverse the order ,that is :-
positive (+) first , then negative (-) last
aitch
Location: in a place far, far away, well Somerset for now!!!
Re: Starting Grief
Post by aitch » Mon Sep 20, 2010 9:24 pm
welcome to the forum Hwilliams click on user control panel top right and put in your location then someone local to you might be able to help you more. good luck with it.
