Starting Grief
Posted: Sun Sep 19, 2010 7:02 pm
by Hwilliams
Hi. New to this techmalarckie! Need help/ideas please.
Bongo Diesel. All was fine. After lack of usage wouldnt start. Fully reCharged Battery and checked. Told all was fine with it.
Charge and discharge all ok. Barely turns the engine as though drained. Wont fire.
Cheers.
Re: Starting Grief
Posted: Sun Sep 19, 2010 7:16 pm
by wonkanoby
reads like a dodgey battery to me though still
Re: Starting Grief
Posted: Sun Sep 19, 2010 7:27 pm
by munroman
wonkanoby wrote:reads like a dodgey battery to me though still
Agree, plus check all the leads are clean and tight, might be worth taking off the battery terminals and cleaning with some fine sandpaper, also clean the inside of the battery clamps.
Make sure the clamps are tight.(I think someone traced their problems to a loose clamp.
Check that the battery earth and engine earths are in good condition, as they may have corroded whilst the Bongo was laid up.
Re: Starting Grief
Posted: Sun Sep 19, 2010 7:40 pm
by mikexgough
Sound advice and always start (excuse the pun) with the basics....Clean up terminals and check the tightness of the clamps......... Could still be a cell on it's way out in the battery....and if your unsure of battery age or if it has a JIS number.....bin it ...
Re: Starting Grief
Posted: Mon Sep 20, 2010 11:45 am
by 321Away
could be starter motor related?
Julian
Re: Starting Grief
Posted: Mon Sep 20, 2010 2:29 pm
by wonkanoby
not normally
they usually default to clicking
not turning over slow when the contacts wear
Re: Starting Grief
Posted: Mon Sep 20, 2010 6:33 pm
by wormey
Hwilliams wrote:Hi. New to this techmalarckie! Need help/ideas please.
Cheers.
Where are you, Sounds like battery to me.
Re: Starting Grief
Posted: Mon Sep 20, 2010 8:11 pm
by bobngo
if you are going to clean the battery terminals,
disconnect negative terminal ( -)first ,then the positive (+)last
when you reconnect ,reverse the order ,that is :-
positive (+) first , then negative (-) last
Re: Starting Grief
Posted: Mon Sep 20, 2010 9:24 pm
by aitch
welcome to the forum Hwilliams click on user control panel top right and put in your location then someone local to you might be able to help you more. good luck with it.
