Just need a quick reality check...
Today I graduated into Ye Grande Ancient Order of Bleeding Bongonauts having just done my very own full drain down, refill with fresh coolant and bleed.
2 questions have arisen...
Upon starting it from cold (and doing the whole funnel, see-saw, revving malarkey), I felt the bottom rad hose after only about 8 or 9 mins and it was already hot. I continued to bring it right up to temp for a further half an hour or so, all the while doing the revving thing (3 mins at 2.5k rpm followed by 1 min tickover... ish). During this time the temp gauge rose to around 30% and then just sat there on the button. So then I took it for a spin. After driving at about 30mph for a few mins the temp started to drop to around 5%. Whenever I now drive fast (40 to 80mph) the temp needle drops right off the scale to 0% - or more accurately about minus 10%. Then if I drive through London traffic again it goes back up to the 30% mark. The temperature of the engine seems to be governed by speed. Oh, and the heater seems very feeble (on the motorway). Am I correct in thinking that the problem is due to the thermostat either being stuck open (or even missing)!?
If the engine is running cold like this do I risk damaging it? Obviously I'll get round to fixing it sometime over the next couple of weeks but in the mean time is it safe to drive? At 30mph? At 80mph?
The other thing is, when I went to replace the coolant it came up to level (full) after I'd only put in about 8 litres. Should I have undone the nearside rad bottom hose when I drained down? Or is it sufficient to just undo the rad drain cock on the bottom offside?
Also, one last question - what are the thin pipes going into the bottom of the rad which, as I found out by accident when replacing a jubilee clip, contain oil? Is this some kind of engine oil cooling system?
Sorry if these questions are very elementary to some of you guys - as you can probably tell I'm willing but inexperienced when it comes to mechanics.
Many thanks in advance,
Ye Ancient Grande Bleeding Master
