Freda has always had starting problems in respect of it starting after the glow plug light goes out but then intermittently idles poorly. If we turn it off then on sometimes it will be ok. We are getting white diesel smelling smoke. This is only from cold. We have had glow plugs replaced four times in 18 months.! The glow plug relay and fusable link were replaced early last year. Very recently, after cooling problem, have had a new head and all gaskets fitted, plus new thermostat, water pump, and heat sensor, but the choppy idle still remains.
Chris & Steve
