acid smell when starting the bongo
cabte
Post by cabte » Thu Dec 02, 2010 12:58 pm
For the last few days when i start the bongo in the morning i get a smell of battery acid in the bongo also when starting the lights on the dash dim then go bright then dim then go bright three times like i have a flat battery
but the battery is full.
any ideas
jaylee
Re: acid smell when starting the bongo
Post by jaylee » Thu Dec 02, 2010 1:13 pm
What's the tickover like when warming up? If diesel, glow-plug relay clicking in & out causing a drain?? Just ideas... :idea:
Do you have the AC on when starting, for defog? That will click in & out...
Another one maybe a short somewhere in the dash, smelling a little like that?? (but then yer fuse 8 would blow.)
Post by Northern Bongolow » Thu Dec 02, 2010 1:24 pm
i would get a meter on the alternator,see if its overcharging the battery,
Post by g8dhe » Thu Dec 02, 2010 1:32 pm
Also double check, clean and remake the battery terminal connections also the ground connection from the -ve to the chassis.
cabte
Post by cabte » Thu Dec 02, 2010 2:25 pm
Its a petrol 2l tick over has never changes just below 1000 revs when cold and just under 1000 revs when warm.
Not had to use the AC as its not that cold here yet 8) also for some strnage reason my window on the bongo never frosts over,
Iv tested the allternater its fine,
all fuses are ok its not like a burning smell, and only does it first thing in the morning or when i start the bongo for the first time. after that its fine.
realy strange,
Post by Northern Bongolow » Thu Dec 02, 2010 2:44 pm
carl the heater circ vent is behind the battery,just wondering if its picking up the stink that way.
try checking the battery(is it leaking) is it overfull of acid,check the caps are tight if it has them.take the batt out and check its not cracked on the casing.check the voltage from the alternator just after a start,it may be going to high at this time,
check the heater air ducting is tight up against the bulkhead.(2 bolts)
cabte
Post by cabte » Thu Dec 02, 2010 6:17 pm
Just had a quick trip to wheelquick they checked everything and all is ok.
Gave me a spare battery just in case, they think its just the cold weather .
dandywarhol
Post by dandywarhol » Thu Dec 02, 2010 11:22 pm
I had exactly the same today in the Hiace - checked out battery - 1 cell dead :cry: battery trying to charge but doesn't hold a charge.....................
lazyb5
Post by lazyb5 » Thu Dec 02, 2010 11:53 pm
Is the heater inlet different in diesels as i have a large flatish air intake for the heater at the top of the radiator and the engine intake behind the battery?
Post by Northern Bongolow » Fri Dec 03, 2010 5:47 am
the large flat intake on top of the rad links to the heater,but when on recirc it pulls air from the bulkhead under the passy side dash,if any of this ducting is leaking it may let the battery fumes into the heater system.if it has a winter flap on the inlet of the heater,it may also pick up the fumes through this,as its designed to pick up radiator heat to help the heater get hotter.
apole
Post by apole » Fri Dec 03, 2010 4:23 pm
On mine there is a small metal lever on side of the air intake. From memory it must be forward to draw in fresh air. If it's backward it draws warmer air into the ventilation system, so is then more likely to draw in any engine bay smells.
cabte
Post by cabte » Fri Dec 03, 2010 4:46 pm
will have a look to see what mines at.
when you say pushd forward do you mean pulled to the front of the bongo or pushed forward to the back of the bongo
