water dripping from side of engine just below turbo
toal42
Post by toal42 » Thu Dec 09, 2010 1:17 pm
please dont tell me this is cracked cylinder head..... it is loosing water from side of engine just below turbo, looks like it coming from something thats bolted onto side of engine.., help!
helen&tony
Re: water dripping from side of engine just below turbo
Post by helen&tony » Thu Dec 09, 2010 2:13 pm
Can you post a photo of the leak, and an approximate region where you live..you may be close enough for someone to take a look
toal42
Post by toal42 » Thu Dec 09, 2010 2:44 pm
hi helen, gunna take a photo and try and put it on here, i live in south tyneside, cheers
helen&tony
Post by helen&tony » Thu Dec 09, 2010 2:50 pm
Add your location in your user CP
I'm hoping that it's something simple like a turbo coolant hose for you [-o< [-o<
toal42
Post by toal42 » Thu Dec 09, 2010 3:01 pm
well ive took some pictures off my phone, now to find out how to get them on here.
321Away
Post by 321Away » Thu Dec 09, 2010 3:01 pm
Dont worry if its what i think its not the head, there is an aluminium plate thing bolted there,under/behind the turbo, IIRC it has a heat exchanger for the oil system, I've seen a few of them with cracks, but its not common, its quite tricky to replace it too as it involves removing a few parts,
Julian
toal42
Post by toal42 » Thu Dec 09, 2010 3:25 pm
hi , that sounds about the area its coming from, just below turbo, and its bolted on, and i can see a crack running from 1 ov the bolts about an inch long, is it expensive to replace,
321Away
Post by 321Away » Fri Dec 10, 2010 10:29 am
No idea of the price but its the section enclosed at the top,14-300 and is the big outer casing. http://www.lushprojects.com/bongopartsm ... mgno=.html
Julian
toal42
Post by toal42 » Fri Dec 10, 2010 3:16 pm
thankyou for your help, much appreciated.
